EdrikLongtail
Hello, After a few things over specs and stuff i started to think and could ue some input befor i get pist off and probly make a mistake here and then lose intrest and become a honda nazi
Im thinking about doing a 93 del sol, LS engine or gsr engine. I was thinking about doing the LS because well their somewhat a dime a dozen and that they are cheap and because low compression ratio i could ram as much boost as i could with built internals
I know GSR got high compression ratio a little higher then the LS but its also got that High end power from the vtec. but its also expensive
I wana be able to run boost, and im not worried about smog or emssions. But i wana be able try to keep it to obd-I and kind of do the engine swap kind of cheap untill i can put a junkyard turbo and build from their..
this would be alot of help (plz mind the spelling)
