kaoskustoms
i hev been kicking around the idea of selling a vtec sub harness for people doing a vtec swap on civics 88-00, also intergas from 90-00. this will include the plugs to plug in vtec sol and press switch, with a disconect at the shock tower and a ground mount for the pressure switch then the wires into the cab, for vtec sol and pressure switch with the correct pins installed. this will also in clude the diag for instalation.
here is the end that plugs into vtec press switch and solinoid
this is the shock tower disconect
this is where you run it through the fire wall
ground for vtec press switch
this is in the cabin and how to wire it claen in to the ecu plastic
this is the wires in the plastic boot ready for splicing
here is the wire added for a4 on the ecm
for d6 fuzzy pic
all wired and ready put back togher plastic boot now it looks like it is from the factory
and the upper shoot of the boot
couple pics of the work bench/ tool box
so there you have it!
let me know if you need a sub harness
so my question is does any one want one and if so how much is this worth to you?
for d6 fuzzy pic
