"Guaranteed to Pass Emissions" Formula
Discussion in 'General Tech and Maintenance' started by Rabinzero, Nov 14, 2006.
  1. Rabinzero
    Rabinzero Senior Member
    Texas
    Anyone ever heard of or used this stuff??? Is it even worth trying?
    http://www.crcindustries.com/crcwebcanada/Portals/0/canada/automotiveimages/75060b.jpg
    Finally got my car to be able to be tested using the tailpipe test, but it didn't pass the low speed testing. The NOX or is it NOx was high. High speed it passed fine. Was wondering if anyone here has actually tried this or can recommend something like this that actually does help.
  2. eg6sir
    i tried it and it didnt work, but my O2 sensor was bad so thats why i failed..
  3. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    That stuff is like octane booster. It's crap. High NOx usually means it is running too lean, or at least that is what I have been told. Check your O2 sensor, also check for vaccuum leaks. Get some injector cleaner too if you haven't done that in a while. Is there anything wrong with your car that you can tell from driving it?
  4. Rabinzero
    Texas
    I do believe I need to be getting around to replacing my cat converter and like you mentioned, put some injector cleaner through it. Any particular kind you suggest?
  5. divisii
    divisii Member
    obvious? do injector cleaner. I stick with namebrand, but all seem the same ... & tuneup- wire/plugs, cap, & rotor
  6. Remedy
    Remedy New Member
    Nor Cal
    I was told a story about pouring a quart of ATF into the tank helping a vehicle pass an inspection that it had previously failed. The guy was saying that the readings were extremely low. Maybe the story was embellished and maybe it was pure horseshit. I don't know anyone who works at a smog check station, but those folks probably know better than most what works and what doesn't. Id probably try that if I was running out repair options.
  7. reikoshea
    Dallas, TX
    DO NOT put ATF in your gas. Thats just not smart. If your reading high on NOx, pull some timing (hopefully your obd1) and that should help a bit.
  8. raidmax
    raidmax New Member
    East Coast
    Try "Sea Foam". I used it and it worked pretty good! You can pick some up at your local AutoZone / Advanced Auto.
  9. reikoshea
    Dallas, TX
    werd to seafoam, but i would recommend doing it at a friend's farm or something away from a highly populated area. when i did the seafoam treatment to my lude it was like i had blown a head gasket. The ammount of white smoke was just plain staggering.
    the only thing about seafoam is that when you start putting it in through the pcv, be VERY careful to do it very slowly. If you let the PCV suck it up too fast you can potentially hydro lock your engine.
  10. racer_XX
    racer_XX New Member
    nox is created with the high temp in the engine, hence the EGR valve. its puts inhert gas in which lowers combustion temp which lowers nox. and guys please dont waste ur money on injector cleaner that u put in ur gas tank it does little to nuthing. get a real injector clean with a pressurized tank hooked to ur fuel rail with cleaner in it.
  11. Rabinzero
    Texas
    It finally........f'in.........PASSED! Problem was a bad converter. I installed a new one, took it in, and it passed with flying colors. Thank you all for your suggestions. This board is great!
  12. GSRCRXsi
    MD
    hmm, any chance of passing with no cat? my race car is gonna have to be tested this summer. im running a custom sized test pipe, and putting a cat on isnt a bolt up affair. id have to get one custom made up to be the right size.
    just wondering what to expect. everytime ive gone to get inspected, they dont even look under the car to see if it has a cat, they dont even look under the hood. they just make sure the gas cap is tight then puts it on the rollers/sniffer. what results can i expect from no cat? high HC, high NOx? anything i can do to try to fudge the numbers (with the ecu, or other adders to the gas tank)
    motor is a built b18c
    11.5 comp
    s2s2 cams
    320 injectors
    tuned on crome
  13. phunky.buddha
    Dallas / Fort Worth, TX
    I don't know what the test results look like without a cat, but I do know people in the Dallas area that passed the sniffer without a cat in place. All it takes is good tuning. :)
  14. MikeBergy
    Central Coast, CALI
    I HIGHLY doubt you will pass with s2s2 cams and no cat. Tune or no tune. If you want to try, get a pretest to see where you are at. If you are running too high in HC, lean out the idle. Too lean a condition will cause combustion temps to go up, and NOx emissions will likely increase. With 11.5:1 cr, you are likely to be running higher NOx anyway. Advance the timing a bit if you can, and it may aleviate this some. Just make sure you save the bin as a smog only bin, and revert back to your previous tune after smogging is all said and done.
  15. GSRCRXsi
    MD
    yea, if it comes down to it, ill just grab a carsound cat and weld it up to the right length but i want to avoid that, if possible.
  16. MikeBergy
    Central Coast, CALI
    :werd: let me know how it goes. At least if you get a cat, your exhaust won't smell so bad. lol
  17. phunky.buddha
    If you put a cat IN your exhaust though, it WILL smell bad.
  18. MikeBergy
    Central Coast, CALI
    LMAO....haha
  19. GSRCRXsi
    MD
    oddly enough my exhaust doesnt smell bad at all. just smells like exhaust fumes/burned fuel, etc. smells good :)
  20. Smogprobs101
    Smogprobs101 New Member
    well from my experince g2p is a cleaner you use it before the test i would try acetone 2 onces per 10 gallons of gas should lower you also if you have an egr take it apart and clean out the carbon hope this helps
