guru's needed...... 90 ls teg.....REWARD
Discussion in 'Integra' started by 90lsteg, Oct 15, 2008.
  1. 90lsteg
    90lsteg New Member
    Moscow Mills
    the car will idle fine with all four cylinders. but once i go and try to drive it it will start missing. brand new 6al ignition box brand new ignition rotor new spark plugs and decently new distributor and spark plug wires. car also has a new o2 sensor. the car is chipped both the ecu and chip is good. could it be the ignition timing. cause i was thinking about it last night and after my buddy did the ignition timing it only ran for about another 100 miles and started missing. he set the gun for 17 degrees i believe. another problem is sometime ill start it up and itll run really rich like a 11.5 on the standalone and sometimes itll be more around 14.8.
    if any more info is needed please let me know. whoever knows whats wrong will get an reward payed through paypal.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    do you have any check codes
  3. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Ignitor? Ya i got nothing. Timing could be it, since you have most of the ignition covered.
  4. BrutalB83
    Rochester Hills, MI
    Why didn't you just bump your old thread?
  5. 90lsteg
    90lsteg New Member
    Moscow Mills
    no codes. im completely stumped
    was in a hurry and needed to leave for work. everytime i fix one thing something else happens. you think it could be the blaster cap? would it allow the car to idle but start missin when its in gear and puttin a load on the motor
  6. AHHVTEC
    Alabama
    yeah just check your timing then
  7. 90lsteg
    90lsteg New Member
    Moscow Mills
    timing is fine. its right on the money.
  8. teggyguy
    teggyguy high density foot.
    Colorado
    plug wires? lol
    i use to have an issue with that but this sounds a little bit different.
  9. dacheat
    dacheat ..is grounded.
    strongbadia
    loose or less than great rotor? i just had your symptoms last week and that's what it was; loose screw on my rotor; rotor's edge slightly corroded. replaced rotor, tightened screw, got perfect idle/rev and bonus 8mpg fuel economy improvement.
    re:
