yes it will, as long as its the internal coil. just conect it to the 2 wires on the coil make sure you protect them so they can't touch each other and so that they don't get in the way of the rotor.. just cut a small U shape in the bottom of the cap where it is closest to the wires and dont' go to big you don't want to get alot of water or mositer in there.. then just get spark wire from the cap to the new coil.... this is a nice setup i did it on my civic cuz msd coil was cheaper and better and mine keep burning out ... since i did this i haven't had a problem since
