H22 eg civic
Discussion in 'HYBRID -> EG-EK / DC' started by chops95ex, May 18, 2005.
  1. chops95ex
    chops95ex Junior Member
    Ive heard of using integra axles with accord/prelude half-shafts. I would like a little more detail on year and modifications to make this work
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    We used two 93 GSR axles, i cannot remember which side, but one of the sides, fit right in without any modification.
    The other side had to be h22 inner and GSR outer.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The one you need the GSR outer for would more than likely be the drivers side, since you are using the Prelude halfshaft, and the Civic hub :)
  4. VTECin5th
    Phoenix Az
  5. chops95ex
    is this any cheaper than just buying the swap axles.
    how difficult is it to change the ends on the axles
    thanks for the help, havent decided which route to take yet
    stick with my Z6, or swap. i can get a complete 98 prelude from a
    buddy for a grand [tree fell on it]
  6. VTECin5th
    Phoenix Az
    do the swap, mating axles is simple.
    cheaper=probly
  7. xj0hnx
    C.C.TX.
    Yea, you pretty much just remove the boot and swap teh parts, repack, and install boot.
  8. chops95ex
    thanks guys. ill keep you informed
    :worthy:
  9. H22_EG6
    H22_EG6 Junior Member
    my swap just got finished not too long ago and the axles i ordered from avid need an intermediate shaft from an accord instead of a prelude. so right now im running on one custom stage one axle and the drivers side is a 95 teggy axle. But im wondering if this is the reason why my car shaking so much. i got an alignment but hasnt helped.
  10. Tim@Canspeed.com
    Tim@Canspeed.com Member
    Which is it? Do you have to disassemble the integra axle(s) or do you mean you just need the prelude half-shaft with integra axles?
  11. H22_EG6
    right now i am running with the prelude intermediate, a passenger custom axle from avid, and a driver's side 95 integra axle. Avid said to use both of there custom axles i need an accord intermediate because both of there axles are male, supposedly so they will be the same size to prevent understeer. im trying to get the accord intermediate this week so i can run with the same two kind of axles. hopefully it will not shake as much but all i wanted to know is if maybe h22 civic are all a lil shaky because it is such a bigger engine? or if done right it runs like a regular stock car? thats all
