97h22dxcoupe
senior member
fuel pump stopped working today,main relay does not click on and off ,i turn the key to on position and nothing happens,could it be my main relay or bad pump,any ideas?? need your guys help...
Does your check engine light cycle once when you turn the key to the run position? If not could be a loose ground at the thermostat housing. if yes, then relay.fuel pump stopped working today,main relay does not click on and off ,i turn the key to on position and nothing happens,could it be my main relay or bad pump,any ideas?? need your guys help...
i would think so, there like 15 bucks at napa auto parts
so the main relay was good but not clicking ?
man!!! i ahve two oem feul pumps i would have sent you one for 5$+shipping.....
