h22 integra
Discussion in 'HYBRID -> EG-EK / DC' started by amaru_x5, Aug 6, 2006.
  1. amaru_x5
    amaru_x5 Junior Member
    jamaica
    is it at all possible to put an h22 vtec into a 95 integra?
  2. reikoshea
    Dallas, TX
    anything is possible.
    check this out.
    here are the mounts:
    Hasport Performance Online Store
    you can use the same wire harness, might have to do a little splicing but im quite sure youll be fine.
    the only thing im not sure about is the axles...someone else will have to fill you in on that.
  3. dmmd3
    dmmd3 Senior Member
    Rochester, Ny
    You shuold look into the h2b swap (h22 w/ b16 tranny). They say the b16 tranny livens up the h22 for a sweet combo.
  4. 90IntegraC1
    90IntegraC1 Junior Member
    i put a H22a in my DA...it's sweet.
  5. reikoshea
    Dallas, TX
    what axles are you using for your swap?
  6. NBTSintegraGSR
    NBTSintegraGSR Junior Member
    the axels have to be custom made well dont have to be but is better. If you are going to use the prelude tranny. you have to get half inner axel to fit the prelude tranny and then the outer axel to fit the integra its pretty simple to do the hard part is to find someone that can do it :p
