H22 Swap into a EG
BrowNKiD
Member
This comming summer i am goin to get a h22 swap... im am getting the swap done profesionally but i was wondering what is involved in swaping a h22 into a civic?
i have a few questions about h22a...
do all jdm h22a come wit lsd?
is a h22 a cable tranny?
wats the redline on a h22a type s and normal?
wats the difference between a type s/s and a normal h22a?
Quoted post[/post]]
no, not all are lsd.
it uses a cable shifter with hydraulic clutch action.
the normal redline is 7200 i think, not sure abouth the type s.
type s has more cam and compression.
type S will make power to 7800
Mounts axles wiring are the three most basic. They will also have to cut a hole for your shifter cables and assembly.
If you have any specific questions post'em up ive done a few = )
also you can tell if its a lsd or not by taking the drive shaft out and looking in the box if there is a bar going down its not a lsd and vise vers
