h22a boosting??
Discussion in 'Prelude' started by yohonda, Jan 18, 2008.
  1. yohonda
    yohonda New Member
    k...im thinking about boosting the h22...can anyone tell me how much boost can it safely handel with stock internals....
  2. donny_ptrsn
    donny_ptrsn New Member
    Tucson, AZ
    like 7-10 stock but your are going to need bigger ingectors and a very very very good tune.
    p.s. make sure you search before posting.
  3. BrutalB83
    Rochester Hills, MI
    It's slightly more complicated than that. A lot of it depends on the quality of your tuning. A motor that's tuned well can handle a decent amount of boost. A motor that's tuned crappily or not at all is likely to blow up after too long.
    What are your plans for tuning?
  4. yohonda
    yohonda New Member
    would buying a chipped ecu solve it..??
  5. BrutalB83
    Rochester Hills, MI
    That's part of the answer, yes. But a chipped ECU isn't a "one-size-fits-all" solution. A chipped ECU needs to be programmed and tuned specifically for whatever engine setup you're going to be running.
  6. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    and sending it to mugen and telling them what parts are on your motor does NOT count. good tuning can ONLY be done with the car in front of you.
  7. N/A b18c1
    N/A b18c1 Mysterious
    Mid-Coast
    I always wonder why, the ones who ask the question never actually question themselves.....Its just not getting the ecu tune....its just not bigger rc infectors....its just not oem parts that will put the power to the ground...specify your needs and do it right....
  8. yohonda
    yohonda New Member
    well my buddy uses his lab top..he hooks it up to his ecu and does everything so i guess i could do that and be my best bet..?h22 stroker kit...drop compression..might be costly but for high boost right?
  9. YBLEGAL
    NW Indiana
    yes if he does that, he's probably got the stuff to tune. you also need a wide band lambda sensor, and a PLX device or something to feed it to your EMS. Make sure he's got experiance tuning hondas. the quality of the tune will determine how long your motor lasts, and that's exponentially more true with boost
  10. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    hondata, aem, crome, uberdata etc.....
    bigger injectors, t3 60-1, decent intercooler....shoot for 300whp. you should be able to make that power with 10ish psi
