H22A Type-S in 92' lude
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Defiant-EG2, Apr 27, 2006.
  1. Defiant-EG2
    Defiant-EG2 Junior Member
    Nagoya, Japan
    My buddy has a 92' Prelude, and we have recently recieved an H22A-S. We have everything we need, but just dont know what relays to hook up, and which ones we dont need. We just need a kinda "walkthrough" that shows us how to do it. It is an Si w/4WS (H23A1). Please if anyone can help. It would be appreciated. Thanks!
  2. reikoshea
    Dallas, TX
    thats a new one. do you have an obd1 type s or is it obd2?
  3. Defiant-EG2
    Nagoya, Japan
  4. reikoshea
    Dallas, TX
    thats gonna be fun....i know youll have to do some injector wiring, add a bunch of wiring (unless you have an H22A4 harness). I dont have a write up, but its gonna be difficult.
  5. Defiant-EG2
    Nagoya, Japan
    A guy on Honda-Tech said i could just use the H23 fuel rail, and wiring harness cause the Si is ready to be wired for Vtec ? Im confused.
  6. Sparky2211
    Sparky2211 Junior Member
    Well i've been trying to do this swap for a month now.. Going from the stock F22a1 to a H22a4 and man is it a bitch.. Right now i am stuck with no spark... Good luck with everything!
  7. Defiant-EG2
    Nagoya, Japan
    Is the Si prewired for Vtec. If so arent the Injectors the same size ? Can't i just use the OBD1 Harness, and wire up vtec ?
  8. reikoshea
    Dallas, TX
    injectors arent the same size. and the s has a different type of injectors (one is peak and hold the other is saturated...i dont remember which is which) The si isnt prewired for vtec, but its an easy install.
    As for not having spark, i think you need an OBD1 dizzy if you have an obd 1 computer, if not you have to rewire the obd1 harness to plug into the new distributor.
  9. Defiant-EG2
    Nagoya, Japan
    Thanks for your help. If you find out anything on how to do this, let me know. It would be appreciated. Thanks again!
  10. kmsmartt
    kmsmartt Junior Member
    i did the same swap in my 94 4ws and i reused the h23 fuel rail and injectors . theh22 injectors use a differant resitor block. i also reused the h23 computer and purchesed a msd rpm acctivated switch that you can dial i what rpm you want the vtech to kick in. mine is adjustable from 3200 rpm to 5200rpm . factory is about 5200, but it kicks in real nice at 4000 rpm . i have had no problems and have had the car up to the 140s with this setup. i also had to reuse the h23 distributer.
