h23 into 90 accord
Discussion in 'Accord' started by RamoncilloSI, Mar 19, 2009.
  1. RamoncilloSI
    RamoncilloSI New Member
    kissimmee,FL
    I have the engine in place im just trying to figure out how to wire the external coil and the knock sensor. im using the harness from the f22. any input would be appreciated!!
  2. 92AccordJDM
    92AccordJDM New Member
    ct
    for the dizzy you can rewire it theres a black and yellow wire then a solid yellow one if im not mistaken there is a fourm up on cb7 which shows the wires in a picture http://www.cb7tuner.com/vbb/showthread.php?t=81303 i know its for a f22b but it should be the same dizzy. im doing a f22b dohc swap and i have to do the same thing but i dont have to put a knock sensor in. so im assuming you have everything else wired up i still havent gotten that far on mine cause the axels are being a huge pain but its almost the same swap minus your have vtec im assuming?
  3. RamoncilloSI
    kissimmee,FL
    no vtec but therea sensor under the plenum that looks like a knock sensor, im using the axels off the prelude.
  4. Ethan
    Ethan Well-Known Member
    When you get it together i wanna see a video on how it pulls. i was thinking of doing this swap too.
  5. jesse accord
    jesse accord New Member
    hey u have to use the the coil from h22 notf22
