h23 vtec?
Discussion in 'Engine Building' started by RiCe RoCcEt, Jan 25, 2005.
  1. RiCe RoCcEt
    RiCe RoCcEt Junior Member
    hey, i heard this is possible, so heres my question, my friend has a 93 prelude h23 a/t, he's seeking to get VTEC for his car, what is needed for this conversion? i know that you need a h22 head and a vtec controller (can anyone recommend any good vtec controllers). thanks in advance
  2. lude9593
    lude9593 Senior Member
    Mt. Pleasant, NC
  3. azn_pryde
    azn_pryde Junior Member
    i kno apexi has a new v-tech controller out...its nice :D ..a buddy of mine has it
  4. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    There's alot more to just bolting on a Vtec head... and getting a "Vtech" controller. You have to change everything that touches the timing belt, unplug an oil orifice on the block or run an external oil line for the Vtec, etc... There is alot of stuff. READ, READ, READ!!!
  5. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Your friend would be better off just buying a JDM longblock and a vtec ecu. You can reuse your transmission.
    The Longblock
    Check my signature, projekteg can hook you up with an ECU
  6. bjfisher
    bjfisher Senior Member
    its vtec not vtech....c'mon
    i'm doin a h23vtec as we speak, alot is envolved, and a lot of research will be needed.its out there, just gotta find it
  7. bjfisher
  8. sr20b20lsvtec
    sr20b20lsvtec Junior Member
