h23a3 non vtec / with vtec
wickedlude5150
I did a swap.I have a 92 lude that came with a 94 h23a3 non vtec.I dropped in a 99 h22a vtec.I used the h22a harness.with the dizzy,alt,injectors.I got no spark or fuel.it'll crank but no start.I tried to use the ecu from the h22a.which is a p5m .but found the connectors are different the ecu that came with is a p14.and I tried a p13.the head is a p13.should I use the harness,alt,dizzy an the p14 ecu from the h23a3 on the h22a in my lude now? Somebody plz help.I'm at my witsends with this.
You'll need to use the p13 to plug into your car, and attach all the obd1 electronics from your orig car to the obd2 motor you swapped in.
