Hard shifting 92 Accord
Discussion in 'Accord' started by afalconfan, Oct 1, 2008.
  1. afalconfan
    afalconfan New Member
    I'm a little new to working on Hondas but not cars in general. My 92 accord 5 speed (over 300,000 miles) doesn't like to shift. In cold weather if it's not in the gear you want to go when it's first started it's VERY hard to pull it into gear, doesn't like to down shift (into first epically!). Clutch seems fine. My cables don't seem to have any adjustment at the shifter. What is it bad syncros.? Also how much trouble is it to put an automatic in as I have a parts car? Bad idea?
  2. eg6sir
    synchros
  3. nootrac22
    exeter pa
    YEP
    prolly cheaper if you can put a new transmission in yourself then to have someone rebuild it for you. you can find accord trannies pretty cheap. I've seen them for about $350 on ebay.
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Check your transmission fluid.
    The automatic swap would be simple, but just changing the fluid is much easier.
  5. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    You mean clutch fluid? it's a 5spd.
  6. Korax
    Korax New Member
    Western PA
    Nope, transmission fluid. There is reason Honda sells two different kinds. ATF and MTF.
  7. 92stoccord
    Salem, Ohio
    huh, didn't know that. touche sir.
  8. afalconfan
    Thanks. The gear lube is full. Would a change of the oil help? I didn't think it would make much of a difference. The hard shifting is worse when cold.
    Any input on putting the automatic trans. in? Other than i would prefer a stick I don't care unless it's a ton of hassle...Isn't there a computer box somewhere that has to come with the autotrans.?
  9. K2e2vin
    Raleigh, NC
    Definitely change the transmission fluid. Some people change it every 3 oil changes or even closer intervals. Don't use those gear oil though, stick with Honda MTF or Synchromesh-specific fluids.
    The TCU is under the passenger seat I think, and yes, you'd need it. I think you'd have to wire that in too.
  10. afalconfan
    Thanks for the info...now I'm off to the wrenches!
