alexfleury
I have a stock 1991 Civic EX. The car has a history of sometimes not wanting to start. Have had all the grounds cleaned at a shop that was familiar with the problem. This seemed to fix the problem for awhile. Recently had the alternator replaced just a few months ago. This seemed to fix the problem for awhile.
The incident when the alternator was replaced happened like this. Drove the car a few blocks, it had been running normally for months. Got in it, hit the starter, the motor turned over well, engine would not start. This has happened before. At seemingly random times. Got the car to the shop, where they said it did start, but they checked and found a bad alternator.
Yesterday I was replacing a sub speaker in the trunk. Had the sound system on for awhile with the engine not running. Got in the car and it started OK. Drove about 5 miles to the store. When I got to the store, tried to crank it again to get a beter parking spot. Wouldn't start!! Let it sit for about 5 mins, with all electrics off and it started, once, then wouldn't start again right then. Did my shopping came out and it started fine.
SO my question is this. Can a Honda have enough voltage to spin the motor normally, but the actual battery voltage be too low for the engine to fire? Has anyone else had a similar problem?
Thanks
Alex
Thanks
Alex
