actually, you arent gonna be able to use anything 99-00 unless you get an obd2a-obd2b jumper and use a 99-00 ecu.
YOU CANNOT USE A 99-00 HARNESS IN A 97. YOU SIMPLY CANT. YOU'D HAVE TO WIRE IN A THIRD ECU PLUG. PLAIN AND SIMPLE.
on 99-00 civics, one of the ecu plugs is on the in-car harness, and the other 2 are on the engine harness.
on 96-98 civics, all three ecu plugs are on the engine harness.
YOU CANNOT USE A 99-00 HARNESS IN YOUR CAR. PERIOD.
also, a gsr ecu will work. it'd just be like using a single-stage manifold.
well, it won't fuck up because of the secondaries. i dunno about other codes an shit.
