jtornado
From what I was told by my Honda Master Technician is that it doesn't matter if you put an OBD1 or OBD2 head on your block it only matters if its an OBD0, OBD1 or OBD2 Distributor. For example: I could put an OBD2 head on an OBD1 Block with an OBD1 Distributor, if I wanted OBD1. I always thought if you put an OBD2 head on any block you will need an OBD2 harness. So basically he is telling me whatever your going make sure its the right distributor otherwise it doesn't matter what head.
