head gasket
Discussion in 'Civic and CRX - EF' started by 8ballsin, Jul 31, 2008.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    what is the best head gasket to use to get low compression for a D16A6 block and D16y8 head I am build a turbo mini me
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    or oem with vitara pistons???
    i cant remember if the vitaras are lower
  3. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    do i use the head gasket for the D16A6 or the D16Y8
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
  5. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    I hear the y8 headgasket is thinner than the z6
  6. sevenhillsbilly
    sevenhillsbilly New Member
    i have a fel-pro on my a6z6 mini me its fine
  7. HondaElite
    HondaElite senior member
    fall river.mass
    NOPE..the difference is... because you can remove a layer of the headgasket from the y8 to raise the compression a little the z6 you cant
  8. 89' Project Civic
    thanks for helping me out guys!
