8ballsin New Member Jul 31, 2008 #1 what is the best head gasket to use to get low compression for a D16A6 block and D16y8 head I am build a turbo mini me
INJEN78 HS LEGEND Jul 31, 2008 #2 or oem with vitara pistons??? i cant remember if the vitaras are lower
89' Project Civic d16a6/d16y8 "mini-me" Nov 2, 2008 #5 I hear the y8 headgasket is thinner than the z6
HondaElite senior member Nov 6, 2008 #7 89' Project Civic said: I hear the y8 headgasket is thinner than the z6 Click to expand... NOPE..the difference is... because you can remove a layer of the headgasket from the y8 to raise the compression a little the z6 you cant
