Header Question
Discussion in 'Prelude' started by unholymaker, Apr 1, 2008.
  1. unholymaker
    unholymaker New Member
    Outside Philidelphia,PA
    I have an 1997 H22A4 motor and have been trying to get headers to go with my new setup, but all I can find are headers for 92-96 models. I was wondering if these would fit on. I cant imagine that big of a difference in the years especially from 96 to 97 unless they dont put it down on the applications because of the OBD change. My engine was converted to OBD1. If anyone knows if the 92-95/6 headers will fit up to my 97 let me know or if you know a good manufacturer of headers for the 97-00 years.
  2. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    the H22 wasnt introduced for stock Preludes till 97-01.....
    92-96 only came stock with the F22 and the H23....
    so OBD has nothing to do with them being different....
    and here is a header for ya:
    Megan Racing
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it should fit not matter if its a jdm 1994 h22a obd1 or a usdm 99 h22
  4. unholymaker
    I was looking for something with a bigger collector cause i have a lot of NA mods and are hoping to put out like 250 to the wheels
  5. get_nick
    Washington State
    you'll need agressive cams and JDM type S pistons if you are going to do that.
  6. unholymaker
    exactly what im doing, type s pistons, sleeving, forged eagle rods, lightened flywheel/crank pulley, cams and valvetrain, fuel pump and fuel injectors...
  7. Uncle Buck
    if your gonna go thru that kind of work... just pick up a F22 block for $50 and build that up and slap on your H22 head.... stronger block and cheaper then resleaving
  8. unholymaker
    heh i already sent out the block and my sleeves so thats already had work on it
  9. BrutalB83
    Rochester Hills, MI
    Are you sure about that? I'm fairly certain that there were three submodels, the S, the Si, and the Si/VTEC, which came with an H22 from the factory. I know a guy who had one of these, it had factory VTEC emblems and everything.
    Check it out: Honda Prelude - Wikipedia, the free encyclopedia
  10. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    definitely not true. theres definitely 2nd gen vtecs. and theyre definitely h22s
  11. DAM!!!
    DAM!!! New Member
    93 prelude si came with vtec stock, and all other years until 97 had a choice of vtec or non vtec.
  12. BrutalB83
    Rochester Hills, MI
    Not quite. There were actually three versions offered from 93-96...
    S - Base model, single-cam F22 engine, no VTEC
    Si - Sportier model, dual-cam H23 engine and four wheel disk brakes, still no VTEC
    Si/VTEC (or just VTEC from 94 on) - H22 VTEC engine, even larger disk brakes
  13. Uncle Buck
    hey you go to hell Brutal lol...... this is why i need to stick strictly to 3rd gens:mellow:
  14. BrutalB83
    Rochester Hills, MI
    Heh heh heh heh...:D
  15. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    ummmm no....the h22 began in 93. it was made standard in the 97+.
    why do you think there are obd1 h22's??
    and yes the obd does have something to do with them being different!
  16. BrutalB83
    Rochester Hills, MI
    Well I'm sure he knew they existed before 97, but I think he assumed they were only available in Japanese Preludes and Accords before then...
