Headlights
Discussion in 'Civic and CRX - EF' started by efhondakid, Jun 16, 2008.
  1. efhondakid
    Akron-Canton, Ohio
    Does anybody know if the one-piece JDM headlights from the 4 door EF's will fit in the EF hatch. I know it wont be a straight bolt in, but if the dimensions are the same as far as hieght, width, depth, I wouldnt mind doing some minor fabbing.
  2. efhondakid
    Akron-Canton, Ohio
    15 views and nothing...
  3. efhondakid
    Akron-Canton, Ohio
    Ah...I wanna put a V8 in it too, now can I get some help.:D
  4. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    i believe the 4 door's front end a bit larger..theyll be slightly off , dunno howd you fab em in tho
  5. efhondakid
    Akron-Canton, Ohio
    The brackets are different I know that, but the one-piecers look so good. I just cant find any info on it.
  6. oneofakinduserid
    oneofakinduserid Eh?
    Mebane, NC
    I don't think it will be as flush as you'll want it. you can't even interchange headlights between 2 doors and 4 doors if i'm not mistaken.
