elpayaso201
ok i have a 92 civic with a b18 in it. it has the stock injectors. the other day i was driving home and for some reason my car died. pulled over to see what was going on. well the point is for some reason the number 4 injector is pumping too much gas on the cilinder and it is comign out of the header. and kept filing the piston to the top. ok did comprestion test motor is still good. but runs like shit now. car use to run great. i have a chiped pr4 ecu. changed it to the stock 92 civic one and it still runs the same any cules.???? thanks
