calmfornow
System Failure Racing
ok huge problem. i went to autozone and asked a guy if my slave cylinder could be the reason why my clutch is slipping, and just wines down from high to low rpm's he said that is the problem after he came out and took a look at it. so i replaced the clutch slave cylinder and now the clutch grabs worse and when i race it i shift up and step on it, it just stays at the same rpm slipping untill the transmission gets to that rpm than goes up. its really bad ever since i replaced it, and since i replaced it (last night) every once in a while today (next morning) my check engine light will come on, then off really quick (flashes kind of) and its like she is going to stall out and than it works fine again..it happend 4 times in a 15 min. drive on my back roads its a 91 accord with an h22...please help, need this car running good, daily driver and i drive a lot
