nolimitlowrider
Hey guys
got my swap done today. I did the jdm b16a into my 92 civic si I am running a del sol P30 with del sol wiring harness, but its not the dohc harness I put in the knock sensor wire from my jdm harness. I hooked up the knock sensor wire just as it was done on the JDM harness I also hooked up the grounding shielding wire thats around the knock sensor wire, and also have a jdm P30 ecu And when i drive the car for a lil bit and get on it a lil i get check eng. light And it gives a code 23. knock sensor?? and my autozone book says it dont have a code 23 my 92 civic that is. maybe a del sol with the dohc may have that code...anyone know?? Thanks
