ok my friend just recently swap a Z6 in to his hatch.....but its having problems. frist we thought it was the ECU.....not the problem. then we tried the TPS, still the same.
Heres what its doing, when you hold it steady at about 1400-2500 it wants to stall. and jerks really hard. Any suggestions on what to do?
i had the same problem out of a 93 integra changed out the distributor and fixed it. also i beleive the car is throwin codes 2 & 5.... not for sure but we need to check again.
Thanks
Thanks
