HELP ls crank gsr rods itr pistons gsr block
you need LS bearings, GSR bearings wont fit unless you re tang the large ends of the rods.
I'm gonna use ls crank and rods, the rod bearings are gonna be ls, but my question is the main bearings should be ls or gsr?
Sounds like everyone says LS bearings.....
You can have the machinist shot peen the LS rods for more strength when you bore out the block....its pretty cheap too. Plus you should have the head checked to make sure its true and flat if you are going through all this work....its another cheap safety precaution
so i shoul use ls main bearings?
