Help!!! ME Help!!!! ME ............please
Discussion in 'HYBRID -> EG-EK / DC' started by tEG, Jul 21, 2008.
  1. tEG
    tEG New Member
    First off... I've searched all of hondaswap's forums b4 i decided to post and I couldn't find ne related topics sooo here it is....
    Soooo my problem is that I have a 5 gen civic ex with a gsr swap. I took the swap out of my crx which was converted to obd1. I bought an ls (s80) tranny and all required parts to do the swap. I have a p72 ecu chipped by jet and it worked fine b4 i took it out....I havent installed the iab or the knock sensor yet but it shoulda started . it started up in the beginning but it was running only on 1 cylinder.... I found out water got into the other 3 spark plug holes (no water in the cylinder) so there was no spark... and now it won't start at all...!!!! I don't get no spark or fuel and I don't know why..
    Since then I've changed the ignition coil, icm, wires, and spark plugs..... i changed the fuel pump and relay and also checked all fuses.... I even tested all the removed parts and they started right up in another civic ex.... really stumped and don't know what else to think of... Can it be hydro-lock? ( I don't know how that can be) Can ne one help???!?!?!?!
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    take the header off and look at the exhaust ports, how wet are they and is it water that in there or antifreeze
  3. Dark93DX
    Dark93DX New Member
    B.C.
    you should wire up the IAB and knocksensor anyway. Does it atleast crank over?
  4. tEG
    tEG New Member
    yeah the engine cranks over... I can't really tell but I think it could be antifreeze I remember it had a small leak back then... could it be that it has no compression?
  5. jesuslives
    jesuslives Banned
    in my garage
  6. Dark93DX
    Dark93DX New Member
    B.C.
    where was the leak? if its leaking out of the block then you're fucked, but try to find out where its leaking from.
  7. thetunersource
    thetunersource New Member
    could be a blown headgasket
