jasontyrone
i just installed a new clutch and flywheel when putting trans back in i thought i had it in right as i was tightening the bolts it stopped going in with 1\4 inch left to go. as i sat there thinking whats going on a loud thunk sound happened and it went in all the way im thinking i got it to slip pass the clutch plate but didnt get into the flywheel bering now the question is this bering sandwiched between the motor and flywheel so the thunk sound was it slipping into the bering or is there a space between said parts and the thunk sound was the bering getting pressed out of the flywheel by way of trans
