wolfdawg2
Wolf dawg
My friend just picked up a crx si wire to put in his dx hb. The motor that was in the crx was a obdo b16. The motor in the dx is a obdo ls. The problems we are having are the motor will not start, fuel pump is not coming on brack lights do not work the dash light palsates and the left turn sing light on the dash stays on when the key is on. Is the uper dash wire and the wire to the tail lights and fuel pump diff form a crx to a dx hb????? The motor is geting fuel 11.4 volts on both wire to the injectours and the spark is good fire order is 1324 any info my help also the grounds are 99% and we went over all the wiring from the ecu to motor 5 times.
