help on instaling gauge for honda accord
Discussion in 'Body / Exterior / Interior / Cosmetics' started by penguine_69, Oct 7, 2003.
  1. penguine_69
    penguine_69 Junior Member
    i just bought a set of glow gauge for my 95 honda accord. I'm having problems with instaling the gauge, since those basters didn't send me any instament information along with the gauge. I'm changing the gauge, not cluster. So if you have any information that will help me out, that will be great. :D
    thanks :spin:
  2. civicspeed
    civicspeed Senior Member
    I installed some on my civic not to long ago. Im not fimiliar about how to take apart the dash of an accord, but essentially you just want to get the gauge cluster out. And i do mean ALL THE WAY OUT, then its as simple as removing any screws from the gauge faces if there are any and poping the new gauge faces on over top of your factory ones. Then you just put any screws you took out of the faces back, and stick your gauge cluster back in your dash.
    I hope that was at least somewhat helpful. :unsure:
    --Aidan
  3. Prowler
    Prowler Super Moderator
    B MT
    hit me up on AIM: PhantomProwler and i'll walk you through it. i have some helpful pics too.
  4. Accordturbo94
    Accordturbo94 Senior Member
    PM me if you need more asistanst i own a 94~!
  5. typeRwannabe
    typeRwannabe Junior Member
    i bought some off of ebay for my 96 accord. i recomend not doin that. all screw hole didnt meet up. on rpm gauge i ended up super glueing it down and drilling thru the fatory gauge to get it to sit down far enough so the needle wouldnt stick. as for putting them in it was a pain in the ass and very time consuming if you dont know where all the screws are. i ended up having to take the center console trim peice, cd player, steering column cover, the trim peice around the gauge bezzle and the actual gauge bezel out.
  6. Prowler
    B MT
    you have to remove all of that. i bought probably the same gauges off ebay. the screw holes weren't perfect, but manageable to use.
    look in your haynes manual. it says to remove the center console, radio bezel, temp controls, and the rest of the dash. you have to to get to certain screws.
