help please dpfi to mpfi
well i went to the site fourthgenhatch.com and he said that his car was running on 3 cylinders before he went back and soldered all of his connections and that was something i didn't do, i didn't solder the wires that i cut, so could that be the problem? well my car starts up fine, but i just think it could be that i didn't solder them and the signals are jumping. tell me what you think about this.
didn;t geta chance ot read the whole thread but go through and first pull plug wires one at a time and see if it makes any diffrence, then go back and pull injector plugs one at a time... if you find one that doesn;t make a damn diffrence if its plugged in or not then that could be your problem
well what i did on all of the connections is i just twisted the wires and put heatshrink on them, so what i am thinking is i need to solder and heatshrink them to make a solid connection and get a steady signal.
well when the motor rocks back and forward, is it cause by miss firing.
