so heres the thing, im not smart with wiring so i need a little help, i got a 90 civic hatch si, i did the b16a swap in it this last weekend. you cut the plugs off the b16 harness add extra wire on to it, run it through the firewall, find the correct pin location and splice into the wires?? am i understanding this right?? the second 02 sensor wire can be spliced into the primary 02 sensor wire at the ecu right?? anything else i need to know?? please let me know..
thanks for the help.. skaterjason55@hotmail.com
