Help with a d18 swap!
doublejay2003
Have no idea what i need to do this swap, so i hope someone can help me. I have a 89' CRX Si with a bad motor, and have a 89' integra 1.8 non-vetech motor to put in but i dont know what I need for the swap so that where Im at with this. :shrug2:
you need the b18a motor/trans/ axles/shift linkage/and special adapter motor mounts for your swap. or trade it to me for a rebuilt stock crx si motor. bored new pistons /rings/ bearings
well if you want an everyday driver then do the d16a1, but if you want more power then i say do the b18a
Im putting the b18 in, and I have the motor anyd trans but what i need to know is what else i need like a different ECU or motor mounts exc. because i cant find anywhere how to swap it.
mounts, axles, ecu
check the swap guide at HASport.com
they'll tell you which of their prodcuts you need
and you don't need the b18 shift linkage, it doesn't work without some modification- you need to buy a special set or else do some cutting and welding
