help with dpfi to mpfi on a b18 into an 89 hatch
delsol_racer
im so confused wth tha wires i need help witht ha dpfi to mpfi i slaw a digram on it but it gave me 18pins-20 pins-16pins on tha ECU but on tha
ECU its 17pins-20pins-16pins can someone please tell me what im supposed to ido i want this car running already please someone what im spsoed to do thank you and ill help you guys as much as i can.
thak you
the main ecu plug has an extra pin if it's an automatic tranny, on all the diagrams i've seen, they tend to show the 9th and the 10th pin on the plug. But in all actuality the 9th plug is the actuall clip for the plug and the 10th is for auto trans. The 10th plug is probably red w/ white stripe or vice versa.
