help with engine id
Discussion in 'General Tech and Maintenance' started by raffishx, Oct 22, 2006.
  1. raffishx
    raffishx New Member
    I just bought a 1988 CRX. I was told that it has an engine from a 1998 Civic. I have no way of verifying this right now. All I know is it has MPFI. Can someone tell me exactly how to id this engine so that I can get the right parts and the right shop manual. I am a new member and a first time CRX owner. Thanks.
  2. dazedandconfused
    dazedandconfused Matser Bater
    In A Box
    to the left of the exhaust mani there is a engine code on the block. clean off the dirt and oil and post the code #. then I can help you out. If it a 98 vtec motor it should be d16y8, if non vtec d16y7
  3. raffishx
    raffishx New Member
    i pretty much figured out it is not a 1998 engine, but i don't know if engine is origional or a swap. help if you can.
    engine code is D15B1 4615159
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    That's a stock motor.
  5. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    converted to multi pint injedction^^
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    D15B1 is the 60hp DPFI engine from 88-91 Civic STD (4 speed) model - not a stock CRX engine
  7. D See 2
    Baltimore, MD
    Yes it is. Stock CRX DX engine.
  8. jlicrx
    Colorado Springs
    stock CRX DX engine is 92hp D15B2
  9. raffishx
    raffishx New Member
    I found the info below on wikipedia. Assuming it is correct, my motor (from a 88-91 Civic) has already been upgraded to mpfi. Can I rebuild the D15B1 block and add a vtec head? If so, is there a specific vtec head to look for?
    Thanks for the help guys.
    D15B1
    (essentially a D15B2 engine with a mild camshaft, a restrictor plate under the DPFI, and an air flow restrictor inside the DPFI unit)
    • Found in:
      • 1988-1991 Honda Civic STD Hatchback
        • Displacement : 1493 cm3
        • Bore and stroke : 75 mm X 84.5 mm
        • Compression : 9.2:1
        • Power : 70 hp @ 5500 rpm & 83 ft·lbf @ 3000 rpm
        • Valvetrain : SOHC (4 valves per cylinder)
        • Fuel Control : OBD-O DPFI
  10. raffishx
    raffishx New Member
    While I have your attention...does anyone know where I can get a poly fuel tank to replace the leaking one on my 88 crx? Not a fuel cell to go inside, but a replacement for the stock one. Thanks
