help with swap
Discussion in 'HYBRID -> EG-EK / DC' started by fierceEG6, Aug 14, 2006.
  1. fierceEG6
    fierceEG6 Junior Member
    I just swapped a B18C into my civic. After about a week of getting new parts that would fit we finally dropped the motor in over the weekend.
    The only questions i have now are wiring related.
    If anyone could help that would be great.
    I originally had the stock D16 in my 93si. i am guessing it is OBD-1. I was wondering if it is possible to use the wiring harnes on my b18c and just add the vtec lines...etc.
    the engine came out of a 89 crx and was wired for use with that car. would this be a problem?
    any help would be appreciated.
  2. reikoshea
    Dallas, TX
    shouldnt be a problem. youll probably need to wire up the knock sensor (i think the GSR has one) and the IABs.
  3. fierceEG6
    ok thanks...ive been trying to figure out what IAB stands for...and the site ive been using as a reference for the 7 wires to hook up is
    http://hybrid.honda-perf.org/tech/5gtech/index.html
    where is the Evap purge solenoid???
  4. fierceEG6
    thanks for all who helped and answered my questions!
    my stress is finally over.
    everything wired up nicely with no problems. my existing d-series wiring harness plugged right in with only a few minor adjustments. car is running beautifully although the engine light is on. could be because the ecu is chipped? or a couple of other reasons. gonna have it checked by a pro.
    cheers all!
  5. jegamister
    jegamister New Member
    hey man i got a few questions about my civic i was wondering if you not much about swapping engines or if you know someone that does
  6. jegamister
    i was wondering if anyone ever did a swap and your car runs good at first then it will not start up right away or it dies sometimes.
  7. hb9406
    hb9406 eg b18c1
    TEXAS
  8. jaybuilt
    jaybuilt New Member
    thanks for that diagram it help me out
  9. 95_teggygsr
    95_teggygsr cLeAn_GuNmEtAl_GsR
    FrEsNo
    damn...i know i asked for this kind of help a while back sometime this year...
    i never got any help like this.....this is BS!!
    but anyway...shit! finally!!!
  10. reikoshea
    Dallas, TX
    yeah you know...its the new moderators and user base :)
  11. crxboi
    crxboi Junior Member
    would this be the same for a 99 GSR?
    So would this be the same for a '99 USDM GSR?[​IMG][/quote]
