Help!
Discussion in 'HYBRID -> EP / DC5' started by Siby, Feb 2, 2003.
  1. Siby
    Siby Junior Member
    i need some help - here's the story i have a acura rsx and recently i bought a vtec controler - i heard that the vtec controler wold not work for my car because it's engine is i-vtec - is this true? - if you know anything let me know - thanks
  2. pissedoffsol
    i never heard of this. I'm not sure. what one did you get? apexi?
    perhaps there is some documentation on their website
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If I understand the base RSX engine correctly (and I am not sure I do) i-VTEC on that engine is timing comtrol only (no lift variation). The VTEC controllers made for engines previous to i-VTEC don't have anything to adjust how the ECU changes the cam timing. I'd bet that the VTEC controller won't work with the RSX-S engine either for the same reason.
  4. ekPhred
    ekPhred Senior Member
    you learn something new everyday... :ph34r:
  5. lsvtec
    Don't take my word for it, this is second hand information. If I am wrong please correct me. I just guess that because this is a new VTEC system, it is probably controlled differently.
  6. heishin6
    heishin6 Junior Member
    basically the vtec controller lets you control when you want your engine to engage vtec...
    the i-vtec is basically, once you push you foot to the pedal, the i-vtec kicks in...
    you cannot control the i-vtec because that's the way it suppose to work.....
    i hope that small explanation will help...
    if you know what im saying...
  7. D16z6CrxDx
    D16z6CrxDx Senior Member
    you can use a vtec controller on the i-vtec cars "Power Enterprises P-VTC (Fuel and i-VTEC controller)" is one out there that i know is compatible with the i-vtec. The P-VTC unit has both fuel enrichment, i-VTEC engagement and tachometer output all in one. regarding your vtec controll try it out and install it and see if it works thats the only way u will find out. Get the chilton for your car and find the right wires to splice in the wires to and more then likely it will work but i know that Power Enterprises' works my friend has it.....
