Hey I have a d15 and I want to get a B16
Discussion in 'Civic and CRX - EW' started by sprocket_3, Oct 17, 2006.
  1. sprocket_3
    sprocket_3 New Member
    Eugene,Or
    Does anyone know where I could get a cheap b16 block and tranny for my 88 crx for not a ton of money. I am willing to drive a long distance and build it if its just a block. If anyone knows where to get one of those 30K Japan motors for less than a grand or if someonne has an extra motor they want to sell me email me a sprocket_3@hotmail.com
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    im not sure what you wont to spend but for about 1200 you can get the hole set up and drop it right in
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Your best bet would be hmotorsonline.com , I've purchased several motors from them and had damn near 100% satisfaction...
  4. AHHVTEC
    Alabama
    h motors all the way i can second that
  5. ef8
    ef8 Junior Member
    Its not going to just drop right in,he's going to need mounts and to convert to mpfi
  6. AHHVTEC
    Alabama
    well what i mean in japan they come with a b16 so yes it will drop right in when he buys the hole swap it will come with all mounts ecu and everthing,but he will have to go to mpfi
  7. ef8
    ef8 Junior Member
    You cannot use the stock JDM mounts.The body mounting points are different,you would have to weld in the jdm body mounts too.
    This is from HMO:
    *Requires aftermarket parts for most applications. We can supply you with the hasport mount kit for $300 and the hasport linkage for $100.Prices only valid with purchase of a complete changeover. We can also supply you with 90-93 Integra steering knuckles and hubs for $50 if you need them. Also availabe is the Hasport Aluminum A/C bracket for $160 and the Hasport wiring sub-harness for EF civics that are either HF or Si models (not DX or STD) for $60.
  8. AHHVTEC
    Alabama
    i wonder witch b16 he was refering to.i was refering to the 160hp modle 1st gen
  9. ef8
    ef8 Junior Member
    exactly,you still have to get aftermarket mounts.The mounting points are not the same as USDM.That info was on the 88-91 complete changeover
  10. AHHVTEC
    Alabama
    gotcha:thumbsup:
  11. sprocket_3
    Eugene,Or
    thanks guys Im soory I didn't get on sooner schools been hecktic
    thanks for all the replys I found what I was looking for base on your sugestions
