thechief86
hey guys, this is the first post of many, i'm sure. i just bought a 93 civic with a swapped in b18 from a 94 integra. it wants to idle around 1500-2k once it warms up, and won't go back down. i adjusted the throttle stop, and it didn't change anything. check engine light isn't on. i don't know if the guy used the civic wiring or the integra wiring, but it looks clean, and not much stuff is spliced in, other than a different map sensor. it has the integra map sensor still on the intake manifold, but unhooked, and it's using one mounted on the firewall. this is the first honda i've had that isn't stock, so i don't know much about them. i've mostly messed with jeeps. unplugging the throttle position sensor didn't change anything while idling. i dunno, but i figured somebody on here might.
