honda crx
TITO.CIVIC
ok b20 i have a problem with my rex. the motor have a leak and the alternator is soak wet now it dont work is it posible that i can fix it by cleaning it with a degreaser?
i'm going to go with nope. degreaser is not a can of miracle fixit. fix the leak, dig into the alternator and find out if you can repair it or if it needs replacing.
what is the motor leaking??if its oil then there is a possibility the alt. could be fixed by cleaning it out,
thanks i did spry the alternator and after like 10 min it start but if i take off the - from the batery it turn off.
