Hondata
Discussion in 'ECU's, Electronics, and Tuning' started by dohch22a4, Nov 25, 2003.
  1. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    I'm thinking that Hondata is going to be my best option this summer when I finally have Toda B's and get my S2 intake manny on. I'm just wondering how some of the features work, specifically, the HondaLogger feature and the Rom Editor. If I get these bitches with the Hondata program I can tune on my laptop, right? And if so I can edit my fuel tuning and other shit like rev limiter too, right? Someone told me I'd have to burn a new chip every time I edit with the Rom Editor. Is this true?
    Thanks in advance! :worthy:
  2. dohch22a4
    Spokane, WA
    bizzump <_<
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    Hope this isn't considered jacking, But I am also looking for the same info for a serious purchase. I know there are peeps out there in HS land that know a decent amount about Hondata systems....pissedoffsol?
  4. dohch22a4
    Spokane, WA
    It's cool... this thread needed a bump anyway :D
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i'm what i like to consider the resident hondata whore...
    any specific questions??
    click my webpage in my sig for some hondata tuning info and such...
  6. pills_PMD
    New Albany, OH
    oh and to answer the original post...
    yes. you have to burn a new ROM every time you change your settings, using the pocket programmer or some similar device.
    to save time, tuning on a dyno can be done with an emulator, but the final tune must be burnt to a ROM or else you'll have to run your laptop everytime you drive the car and download the ROm to the emulator...
    you can edit your fuel maps, ignition timing, rev limit etc... but be warned its not as simple as hitting a few buttons.. you have to know what youre doing to pull the most potential out of the car...
    a small very generic how to tune is on my webpage.
  7. dohch22a4
    Spokane, WA
    Soo.... Does burning a ROM mean i need a new chip? Sorry, i'm kind of retarded. :p
  8. hybrid89
    SoCal
    I'm assuming that all of there software is for windows only?
  9. pills_PMD
    New Albany, OH
    you can get EEPROMs which allow the data to be rewritten over and over...
    atmel 29c256 are what i use
  10. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    the Transtronics Romulator can be used as a permanently installed ROM emulator - it has battery backup to retain information.
    If all you are looking for is a way to tune your NA cars, I'd highly urge you to save your money and try the DIY tools. The DIY tools can do pretty much everything hondata can, but at this time they do not handle boost or large (>310cc) injectors very well.
    Crome and Uberdata are the two most well known ROM Editors sprung from the DIY crowd. Uberdata is targeted more at boosted cars, Crome has a extendable scripting language that people have used to implement everything from datalogging to full throttle launch/shift to resized tables.
    One of my homies runs his NA CRVtec with a chipped P28 and a program he made up in Crome. With simple tuning, dropped almost a second in the 1/4, hopes to hit 12s on street tires when the track opens in the spring. Nick had never chipped an ECU or burned a chip for his hondata (that he got rid of) and several months later is runnin all round town making new chips for ppl.
    Point being: if you're willing to learn a little more, you can tune a NA car beautifully with DIY tools, for a lot less money.
  11. riddickone
    riddickone Member
    Heys Pills what do you think about uberdata??
    I know it is FREE, but doesnt it do the same settings as Hondata??
  12. pills_PMD
    New Albany, OH
    i've never used uberdata, but it looks interesting enough.
  13. radnulb
    Sinsinnaty, Ohio
    Uberdata does pretty much the same things as hondata. As of today, what it does NOT do as well:
    -Datalogging
    -3bar boost support
    -Finer closed loop correction stuff (cold start enrichment, brake cut, ... ...) isn't as sharp as hondata
    -Uses stock MAP/RPM scalars
    Cool things about Uberdata:
    -First DIY ROMeditor to support bosot
    -TPS tip in correction = no more bogging when you floor it with big injectors
    -Being actively developed
    Crome does pretty much the same things as hondata too.
    Things it does not do as well:
    -3Bar boost support
    -Finer closed loop fuel correction in general (TPS, Cold start ... ... ...)
    Things it does ok:
    -Datalogging support (through ECU Control)
    -MAP/RPM Scalar manipulation
    -Larger tables for higher resolution if needed
    Things that are really neat about it:
    -Lots of tweaks for odd things like IABs
    -Extendable scripting language for user features
    -Relatively sane user interface
    -Full throttle launch AND shift support
    BTW, you can continue to ask Pills about stuff he doesn't use or ask someone who uses it every day practically. I will continue to answer questions addressed to Pills if I can be of assistance. :)
