Hot zc!!
Discussion in 'Civic and CRX - EF' started by xXHondaBradXx, Jul 22, 2009.
  1. xXHondaBradXx
    xXHondaBradXx 2 FAST 4 YOU!!
    Ontario, Canada
    Hey! For some reason my dohc zc is getting really hot.. the temp gage is less than half but the engine gets so hot its burns to hold your hand on it.. i dont know if i should be worried.. just got the swap goin good!!! And another thing, the swap is in my 1991 civic si hatch, and the check engine light is not on.. arent they suppose to have a check engine light from the cylinder sensor? weird!
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    if everything is hooked up correctly on the engine harness and all of the sensors are good, you should not have a Check Engine Light
