how to wire up vtec to 95 delsol d16 sohc
Discussion in 'HYBRID -> EG-EK / DC' started by delsol_racer, Mar 31, 2007.
  1. delsol_racer
    delsol_racer Junior Member
    watsonville ca
    im getting a single cam vtec next week i was wondering how to wire up tha vtec and is it worth getting a vtec controller?
    i will have tha vtec harness and a chiped ecu so what wires will i run?
  2. dbone_vtec
    dbone_vtec HONDA 4 LIFE
    MASS
    Vtec
    WIRE THE VTEC SOLINOID AND THE PRESSURE SWITCH TO THE ECU AT
    CORRECT PINS = VTEC POPPIN:driver:
  3. delsol_racer
    watsonville ca
    do u know where i can get a diragram so i dont conguse tha wires?
    and is there a knock sensor as well well im assuming ita already wired up to tha harness?
  4. dbone_vtec
    MASS
    Knock Sensors Just On B Series
  5. delsol_racer
    watsonville ca
    well thats good to know lol
  6. dbone_vtec
    MASS
    NO DOUBT, YOU CAN PROBABLY GET PICS OF THE PINOUTS AT THE APEX WEBSITE:driver:
  7. delsol_racer
    watsonville ca
    cool i get tha motor tuesday and im swaping it next monday i think idk yet
  8. dbone_vtec
    MASS
  9. delsol_racer
    watsonville ca
    thanks i know i can get tha motor in tha only fear it tha wiring tha vtec i have swaped that motor like 3 weeks ago and cot a d15b8 and ita a pos with 70 hp nd it cant hit 90 so i got a vtec engine
    and yea a racing clutch too
  10. dbone_vtec
    MASS
  11. delsol_racer
    watsonville ca
  12. delsol_racer
    watsonville ca
    ok so i got tha motor in and tha vtec wont kick i have a p28 chipped with tha stock harrness for tha motor it came out of an EG so it was running im assuming i one question i looked at does tha valve cover have to be grounded? cuz i dont think it is cuz one of tha screws where it get grounded it stripped so it out connect to it im am getting tha 21CEL which is the vtec circut i ran a stright wire from tha a4 pin to tha solniade nothing happended i ran a hot wire to it and it clicks which means its good there is oil in tha car so idk what else to do any tips
    any one?
  13. delsol_racer
    watsonville ca
    also im getting tha 15 CEL which is i belive ingintion out put which in dont know what to do on that either any other ideas
  14. dbone_vtec
    MASS
    grounds are very important, clean all connections to motor and chassis.
    VTEC - have you cleaned the screen at the soleniod;)
  15. killercannible
    killercannible Senior Member
    Not true, knock sensors are also on sohc vtec motors, at least on 96-00. Trust me, they are very easy to break and i did so just trying to unplug it from the harness when i did my b16 swap.
  16. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    i have the same swap and a chiped ecu the vtec is really not that strong so you can only tell if your really paying attention. the stock vtec without ecu is almost unnoticeable.
  17. dbone_vtec
    MASS
    I was referring to his 95
  18. delsol_racer
    watsonville ca
    ok so tha thing is i havwe a 95 delsol with a zc block and a 1.6 vtec head cant get vtec to kick in at all it wont go more than 3000 rpms sometimes its powerless
    i have a CEL of 21 vtec circut and 22 pressure switch
    i was thinking bout putting tha stock harness on and just wire up tha vtec cuz i have tha 1.6 harness onit do u think that would be tha prolbem? or what to u think?>
  19. dbone_vtec
    MASS
    I doubt thats the problem but but try if you want
    The harness for the 1.6 vtec engine will work in your car
  20. delsol_racer
    watsonville ca
    i know that y i dont know whats wrong i dont know y its throwing thoes codes im like at a dead end idk what else to do does ne one have an idea on what else it could be?
