Hyperground Wires?
Discussion in 'General Tech and Maintenance' started by endlesszeal, Feb 25, 2003.
  1. endlesszeal
    endlesszeal Senior Member
    ive been recently reading up on HyperGround Wire systems and they seem to work.. i am about to get a set myself.. i wanted to know if anyones tried it ? or knows if you actually gain more hp.. its been "dynoed" at 5 whp! thats a shit load for just a few wires.. :worthy: thats hella alot better than buying an aerospeed intake for 140 bucks and getting 2 hp.
  2. pissedoffsol
    waste of money.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Good grounds are important, but you don't need to spend $140 to do it.
  4. chevy302dz
    chevy302dz Senior Member
    You can make your own grounds for a fraction of the price, and use the money leftover for new filters, plugs, cap, etc. Much better way to use $140.
  5. phunky.buddha
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    the theory is very sound but with some 4 guage speaker wire and o ring 25 bucks worth of shit you can make your own set you need five wire one goes batt to chasy one engine chasy on alt bracket one intake manifold ground the fuck outa the engine
    the hyper ground oly gives sug they tell you to test diffrent locals
  7. casper
    casper Junior Member
    The Dirty South
    On Group Buy, there are Pivot sets for like 65 bucs :)
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :withstupid: :werd: Don't waste your money,DIY.
  9. NoJokE
    NoJokE Senior Member
    I just bought a set :( hopefully they work good
  10. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    My grounds consists of... Stinger 4 gauge power wire as positive wire from battery... Stinger 4 gauge ground for neg.
    High end stereo wiring transfer more power efficently to the amp, why not through my charging system. :)
  11. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    They will, but like everyone else said, there's just better things to put your money into.
  12. cws13
    cws13 Senior Member
    Athens,GA
    We are selling them like crazy. Apparently with happy results. They do however, work best on turbo motors. Heat, resistence= loss. They work like underdrive pullys for electrical systems.
  13. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I am going to have to kind of dissagree with that (the comparison to under drive pulleys). Underdrive pulleys actually change how fast the coil in the alternator is spinning, making the alternator deliver less current to the electrical system. Where these ground kit just allow the eletrical systems on the engine to ground out easier.
  14. cws13
    cws13 Senior Member
    Athens,GA
    It was a vauge comparison for sake of understanding, not an explination.
  15. sleeperls93
    sleeperls93 Senior Member
    You will not gain an ounce of power, you will only be recuperating lost power due to the old ground factory wires that are on your car; make you own, don't spend the money.
  16. sportlinecrx
    sportlinecrx Banned
    they'll work and they will look tite too. thats one reason why they're pricey...cause they look tite!
