i need help BAD!!!! 88 CRX B18A
Discussion in 'HYBRID -> ED-EF / DA' started by speedrx, Oct 23, 2006.
  1. speedrx
    speedrx OL SKOOL HONDA FOOL
    durrty south
    OK SO i'M NEW TO THE FORUM and I need help surprise i'm getting a crank positin sensor code and it won't rev past 3500 i have all the right parts even a jkobd adapter harness i followed the directions and i don't know whats wrong heeeelllp:confused:
  2. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Check over your Distributor wiring. Check to make sure no pins are slightly pulled out.
    This is what happened to me recently, and it turned out to be just 1 pin loose from the connecter.
  3. speedrx
    durrty south
    thanx for the reply i don't thinkthat's it I've checked all the plugs 3 times. but your suggestion makes me wan't to check again
  4. Andrew
    Tallahassee, FL
    It can't hurt to check once more.
  5. eg6sir
    :werd: no sense in buyin shit if you dont need it..
  6. speedrx
    durrty south
    if i didn't buy shit i didn't need i wouldn' have the crx how much fun would that be
  7. Andrew
    Tallahassee, FL
    haha.... touche....
  8. speedrx
    durrty south
    shit long work days and now the damn thing won't even turn over i think i blew a fuse or relay or something. it 's all right i'm off work for a voluntary layoff next week so i'll neglect the house the wife even myself everything but the car it will run .... or it will BURN!!!!
  9. nikozai
    nikozai New Member
    Kinda sounds like the igniter unit in the dizzy. =)
    Rywire is JKOBD (or has been since Oct. 05) so maybe call us ;)
  10. speedrx
    durrty south
    so the dizzy is new and i put an msd pro cap and external coil on it. i'm thinking about the whole hasport harness, but i'm not sure. i will definitly call you guys. i need help with a capital HEL!!!!
  11. 4x4crx
    4x4crx New Member
    sounds like the motor is in limp mode
  12. nikozai
    nikozai New Member
    man, there should be something in the "new member" thread that tells people what a "dead post" is. Look at the last response to this thread man - over 5 weeks ago.
    And limp mode does not cause a rev limit - it causes a hunting idle.
  13. jahudah
    jahudah New Member
    Hi i'm searching for the timing diagram for a b18a1 engine ...i recently did some work on my engine and lost the timing specifications..
    please help
  14. Andrew
    Tallahassee, FL
    guh-god [/prince voice]
