i need help for b20vtec
Discussion in 'Engine Building' started by alkaaserB20v, Oct 27, 2012.
  1. alkaaserB20v
    alkaaserB20v New Member
    heloo guys
    i hope all fine
    i want ask about the redline for my b20vtec
    information for my engine :
    -b16a1 head from crx 89
    -b20b block from crv 00 ( the piston not p3f is PHK )
    -and p28 od1
    and every thing is stock
    i search about that .... some people say 6200- 6800rbm some say is 8500- 9000 rbm
    so i dont know what the bast and safe for my b20v stock
    but if i make the redline about 8000-8200 is good or not for my engine !?
    ty for red my post and help ^_^
  2. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    ok. well if you are tuning ur p28 and setting redline and motor is stock..
    concern is with block... depending which block it is b20z b20b. and so on...
    if you have no arp rod bolts and stock rods i would not rev past what the b20 block is ment to. which would be around 6800.. but me personally i wouldnt drive it without building the block.
  3. alkaaserB20v
    oky if i want go to 8000- 8200 rbm << what i must change in the block ?
    and if i change it rods and pistons << thay give me more hp or just more rbm ?
    and plz man i new for b20 vtec so what the bast rods u think
  4. alkaaserB20v
    sorry man i mean i have arp rods bolts also the oil kit for block to head also i have it ...
    that mean i can run to 8000-8200 rpm ?
  5. lostsoulzprophet
    georgia
    ok you can go to 8000 all u want but not safely.
    possible damage to engine.
    to do it safely you need h beam rods or shotpeen the rods.. <<< however u spell that name..
    pistons are a plus with higher compression for more power..
    also arp rod bolts are a plus.. h beams usually come with them for a decent price.
    the main thing to do after the build is tune... tune tune tune. without that your almost guaranteed to destroy the motor at some point in time.
    also breaking the motor in. if u do rods and pistons you mine as well get new rings.
  6. alkaaserB20v
    thx man for help me <3
  7. 916em1
    916em1 New Member
    There is no harm in setting redline past 8k when tuning its about how u drive it and how often u plan on taking it past 8k
  8. SlushboxTeggy
    NJ to MA to CA
    Wrong. The parts in a B20 block were designed for a particular redline. You can rev to 8000 one time and grenade the bottom end. The parts are just too weak for that. Doing it once may not kill it, but it will compromise those parts. Then it may blow up at any rpm.
    Make sure you swap in VTEC water and oil pumps as well. You're stock ones were also not built for doing much more than they were designed for. Honda is notorious for designing parts to do what they are suppose to, and not much more.
  9. lostsoulzprophet
    georgia
  10. Magana559
    Magana559 The Warden
    fresno Ca
    Rod bolts are the weak link in the rods, with stock rods we only rev em to 7800 rpm with great success. I have stock rods on my build but I had arp rod bolts pressed on.
    I beat the living hell out of my engine and its still running strong.
  11. dc4dude
    dc4dude Member
    chicago, il
    The difference in the water pumps (vtec vs non vtec) is in the amounts of teeth. The oil pumps are the SAME. SAME EXCAT PART NUMBERS. A big difference between vtec blocks and non vtec blocks is the girdle/pickup assemblies, not to me tion the oil squirters....
