i need help
Discussion in 'HYBRID -> EG-EK / DC' started by lsvtecCivic, Apr 29, 2004.
  1. lsvtecCivic
    lsvtecCivic Junior Member
    i got a ls vtec motor from someone, they had it in their 93 civic, im installing it in my 96 civic. mostly everything is done, but i need a distributor, and i dont know which one is right. i emailed the guy i got the motor from to try to figure out what year the block and head is from but he hasent replyed. how can i tell what distributor to get, there are 2 seperate connectors on the harness, one is a bigger connector with 9 pins i think and the other is smaller with only 2 pins, i tried looking on ebay but i cant figure out which to get , sorry if im an idiot but i need help, thanks
  2. typesiracing
    typesiracing Senior Member
    ny
    you want a vtec distributer and you have to match the obd of your car which would be obd 2 unless you are going to get a conversion harness
  3. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Get a dohc vtec distributor for your year of car. It will simplify your wiring. You will also in that case need injectors from your car or other obd2 injectors, and a obd2 ecu. Or just go ahead and convert to obd1 right now while you can, and use obd1 equipment. You'll need a obd conversion harness for the obd1 ecu you are gonna need, also obd1 distributor, o2 plug, and injectors. If your car wasn't vtec, you'll need to wire for vtec and a knock sensor. Hope this helps
  4. lsvtecCivic
    acually all thats been done ... the car has been convertred to obd1 .... so i should just get an obd1 dohc vtec distributor?
  5. typesiracing
    ny
  6. breed
    breed Senior Member
    New York
    the head has 5 or so little circles on the front of it. the first circle will tell you what year the head is.
  7. MikeBergy
    Central Coast, CALI
    it doesn't matter what year the motor was made, just buy the distributor to match your obd1 electronics, and you should be good. and make sure its a dohc vtec distributor, not sohc, I think there is a difference in the way they are mounted.
  8. lsvtecCivic
    great, thanks a lot guys, you rule
