white91crxhf
i have a 90 rex with a b16a in it and I relocated the battery to the hatch using summits relocate kit and i have a yellow top battery. Anyways, I ran the power wire through firewall to distribution block that splits the wire and one goes to the fuse box under the hood and the other wire goes to the starter. I grounded it to the usually spot ( the spare tire bolt ) and now when you click the key over all the lights come on the dash, headlights work, brake lights work, and wiperblades and everything work. So I go to crank the car over and nothing happends. No crank I dont even hear the starter relay clicking. I went over all the connections and I noticed the other connector that goes to the starter fell out, but before I saw that I took off the power wire the was connected to the starter off. when I found that was off i thought that was it so i put that in and as i put the power starter wire back on i hit some kinda ground in the engine bay with the power wire and it sparked so i went to the battery disconnected the negative terminal and than hooked it all back up and same result as last time. any ideas or thoughts would be very helpfull.
