i show everybody head
Discussion in 'Auto Multi-Media' started by BodyDroppedNikes, Nov 30, 2008.
  1. BodyDroppedNikes
    caught in a mosh...
    yeah i know this is a Honda site, but oh well. anyways, i picked up a "new" 2.3L DOHC head for my 2004 Mazda 3 over the weekend. heres pics:
    i picked it up that whole assembly for $250 at a junkyard where my dad lives. it looks pretty clean. now to put that sucker on,....
    oh, anyone know what to use to remove the carbon buildup on the valves as well as some of the sticky looking residue from the gaskets that were atatched to it??
  2. efhondakid
    Akron-Canton, Ohio
    Damn yo does that bitch have VEETAKCH? :D For the gaskets use a razor blade to clean up the surface, and the carbon build up, not really sure, maybe like a wire brush or something to just knock off the big shit. Any progress on the Ranger?
  3. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    simple green and scotch brite pads? ya razor blade for gaskets, just try not to actually cut/scratch the metal off with the corner of the razor.
    nice find. though, i know jack about it. will this be a performance increase for ya?
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i see a vtec solenoid!!!nah its just t:De injectors
    but like byron said,razor the gasket surface,you can use brakleen on the surface and itll loosen easier,as for te carbon,they make these things from wire that attach to a drill,they work wonders on carbon,kinda like a wirebrush,or have it acid dipped
  5. phyregod
    phyregod !!YTINASNI
    Central Texas
    Dremel with a little wire brush (brass, not carbon steel!!) will make easy work of those deposits. And while you're cleaning it up, you might as well polish the combustion chamber.. :D
    Or, you could soak em down with seafoam and scrub it off after an hour or two. Again with the brass brush. You can use a razor to remove head gasket material, but be very careful not to gouge the surface. Take your time and be gentle about it.
  6. BodyDroppedNikes
    caught in a mosh...
    thanks for the advice y'all/ no this isnt a power increase for the Mazda. its just gonna replace the bad head on the current motor. lol and no it doesnt VTEC but it does have VVT (same thing as VTEC)...lol. byron, no i havent done squat to the Ranger except ive been having to drive it since my Mazda broke down 2 weeks ago :(
  7. eastbxc
    eastbxc Custom User Title
    Kansas
    get it hot tanked cant be to much $$
  8. awptickes
    MD
    Whut? Lol. That'll change the combustion chamber volume. That's typically something you don't want to do.
    OP: Hot tank it. Tear it down, then have it tanked. Install, then enjoy.
  9. eastbxc
    Kansas
    hot tank it will be easier than anything else......i wouldnt think it to be a good idea to scrape away any parts of metal when you could just as easily take it to a machine shop pay a little money and have it cleaned up a lot better
